Imported Surface from Rhino, Heights
famadorian
Member Posts: 390 ✭✭✭
A surface that has been imported from Rhino, it doesn't show correct heights.
The top plane here should be at the water surface.
Isn't this information in the file?
D
D
I have verified points on the surface in Rhino, that they are on the correct height.
I don't want to have to move the surface once I import into Onshape. The whole point of a coordinate system is so that objects import where they are supposed to be and moving it after import can never be exact.
Are their heights not read when importing into Onshape?
Never seen OS get it wrong, my money is on these guys.
