Issue with "Measure Value" custom feature
I have a couple of questions.
First, when I search "Measure Value" in the custom feature menu, I get several results (see screenshot below). Why is this? And which result should I use?
Second, using the first Measure Value feature in the list above, when I select an area to determine its perimeter and click the green checkmark, I don't see any distance value results (see screenshots below). Can I determine the perimeter of a face like the one in the screenshot with the Measure Value feature?
