How to go "Normal" to a face with in a drawing?
Mazie_Houchens
Member Posts: 36 ✭✭
say there's a hole on a off angle direction, is it possible to make a Drawing view that is normal to that angled surface?
PeteYodis
Moderator, Onshape Employees Posts: 575
@Mazie_Houchens You can use the auxiliary view command to project views relative to any edge in an existing drawing view.
You can also create named views in the part and assembly studio and insert those named views by selecting in the view insertion dialog.5
