Need help how to model this part
michael_mcclain
Member Posts: 198 PRO
Hello all,
I have to redraw this old model of a shifter boot for a new manufacturing process and I just can figure out how it was modeled before and how to begin to model it new.
https://cad.onshape.com/documents/9264a7446ebc32f0a3f486ca/w/611841cb3bcefcddf7732348/e/75ae4918184800288fca15d4
The goal is to match the inner dimensions closely enough and to set up the model for variable thickness to allow flexibility with semi-rigid materials.
I believe the original model was done in Creo, but I am not sure as I only have a Step file.
Thank you for any help and modelling tips. I just can't seem to figure this one out.
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
My thought is to make everything as a surface and thicken at the end. I split up the part into four separate sections and labeled them in the order I'd make them.
#1 seems consistent cross-sectionally throughout, so I would sketch the cross-section, sketch a path and sweep
#2 is more variable, so I'd want a path (or paths) that would mimic it. To me, the path looks like a rectangle with fillets and a slight up/down section on the sides. I would sketch both and use projected curves to get the paths. I would then use the edges of the model and the path and use either a fill or a loft between them.
#3 pretty simple, looks to be revolved
#4 looks lofted between the top edge of our sweep and the bottom edge of the revolve
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
NeilCooke
Moderator, Onshape Employees Posts: 6,056
@michael_mcclain - it's not dimensionally accurate, but near enough
https://cad.onshape.com/documents/7b4b0dd908d65a369f51ba06/w/e70035bdc1693f196f26fa31/e/a6f894a27a20ba9a4a899a92
Senior Director, Technical Services, EMEA7
I can make the simple prismatic version of the part, but when it comes to all the fillets and rounds in odd places I am at a loss. There is also the base which is warped in a way that I can't figure out how to replicate it.
I feel like my modeling brain is blocked on this particular model and I need a gentle nudge in the right direction to begin it.
I had also thought to surface model and thicken later, but achieving the various surfaces was the part I just couldn't wrap my brain around.
Thank you for the great help!
@NeilCooke
what a great approach! mastery using the palette of Onshape tools. I especially like the base sketch with mate connectors used for later sketches and the projected curve for bottom. A lot to learn from this one!
I went through your model and I have to say it is some great work. I see a few tricks I will have to incorporate into my workflow. I would have never thought of the projected curve for the sweep path. I forgot that tool existed.
This is exactly what I needed and I learned a few new things along the way. Onshape forum and support is the best!
P.s. @owen_sparks If you want to have a go and throw in some flexibility then be my guest. Might as well throw in the whole shifter and linkage while you are at it haha.
