3D Fit Spline with Pipe custom feature
darren_mason871darren_mason871 Member Posts: 44 ✭✭
3D Fit Spline with the Pipe custom feature is giving me an error saying result of sweep intersects itself, adjust path or profile selections. I think its from too sharp of an angle but I'm not sure.  Could start and end magnitude fix this?
https://cad.onshape.com/documents/b037dcf2f02e757ede3fc628/w/9ee6fea02a2c4a13d8a42a8d/e/8454b16f4b82299662c8a298
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    At the cross-section you are trying to use for the pipe, 5mm, that curve is too sharp and will fold in on itself.
    Jake Ramsley
    Jake Ramsley
