Which command generate "threads" in drawings?
Hello everyone,
Which commands do I have to write in my featurescript so that I can enable thread display in the drawing?
(Without using the hole command):
I need this for external threads and I would like to write my own script.
I would like to select a cylindrical face and add "something" and I can see these small lines and the arc in the drawing.
Does anyone have an idea where to start??? Which function is needed?
And please don't just suggest I should look at the hole command in the source code:
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/75b72139bd104b1bbf74528e
All I can see is this:
Thanks
Thanks
Which is cool but I only want these small lines
You will have to set a hole attribute on the cylindrical face.
It does not work for external threads, though
Here is an FeatureScript to set a hole attribute on a cylindrical face.
Given a hole standard, etc. and a cylindrical face, it sets a hole attribute on the cylindrical face so that threads, etc are shown in the drawing.
You may be able to call it from your FeatureScript, giving it your created cylindrical face.
https://cad.onshape.com/documents/2ae1714eab70e13cde45634d
Thank you very much for the link! I made a copy and did some experimentation with the code.
I'm can change the "major diameter" of the hole and control where the thin lines appear on a drawing. But only if I select an inner cylinder, it doesn't work for external threads.
Also in the side view, the small line are not shown. Only in the section cut view:
Does anyone have an idea how to unhide them?
Maybe I can get these lines without using show hidden lines.
Then they should be solid thin lines, like in the section view.
