Which command generate "threads" in drawings?
sebastian_glanznersebastian_glanzner Member, Developers Posts: 477 PRO
Hello everyone,
Which commands do I have to write in my featurescript so that I can enable thread display in the drawing?
(Without using the hole command):
I need this for external threads and I would like to write my own script.
I would like to select a cylindrical face and add "something" and I can see these small lines and the arc in the drawing.
Does anyone have an idea where to start??? Which function is needed?
And please don't just suggest I should look at the hole command in the source code:
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/75b72139bd104b1bbf74528e
All I can see is this:
Thanks  B)
  • Cappie_PomeroyCappie_Pomeroy Member Posts: 14
    Have you checked out the Thread Creator FeatureScript?
    I'm not sure what it outputs to drawings, but it seems like a good place to start looking for how to add "something" that could become a drawing of what you want.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 477 PRO
    Thanks for the suggestion, already tried that and it does create a 3D Thread.
    Which is cool but I only want these small lines :)
    @sebastian_glanzner
    You will have to set a hole attribute on the cylindrical face.
    It does not work for external threads, though :(
    Here is an FeatureScript to set a hole attribute on a cylindrical face.
    Given a hole standard, etc. and a cylindrical face, it sets a hole attribute on the cylindrical face so that threads, etc are shown in the drawing.
    You may be able to call it from your FeatureScript, giving it your created cylindrical face.
    https://cad.onshape.com/documents/2ae1714eab70e13cde45634d
    @MBartlett21
    Thank you very much for the link! I made a copy and did some experimentation with the code.
    I'm can change the "major diameter" of the hole and control where the thin lines appear on a drawing. But only if I select an inner cylinder, it doesn't work for external threads.
    Also in the side view, the small line are not shown. Only in the section cut view:
    Does anyone have an idea how to unhide them?
    If you show hidden lines in the side view it might work
    Thanks, that worked! Interesting, I think I have to experiment with the code.
    Maybe I can get these lines without using show hidden lines.
    Then they should be solid thin lines, like in the section view.
