import image to document android
darren_mason871darren_mason871 Member Posts: 44 ✭✭
I've read instructions to insert an image into a sketch but how do u import the image to the document on android?
  • karan_gujralkaran_gujral Onshape Employees Posts: 5 image
    edited July 2019 Answer ✓
    You can import an image into a document using the import menu in the tab list. See the help documentation here. The sub-section under Import files: Android -> From within a document has the steps. I've also attached a video with the same steps.
