import of dwg dxf or ipt show absolutely nothing, what am I missing?
Once again successfully imported file .dwg or .ipt parts from acad/inventor shows nothing and properties says "in progress" nothing to see or do just useless import of file name? Watched several vids and they all show the part. The solid works part imported well but none of the other supported formats show any models or model space. I realize you can't work with the files but I though they would at least be visible.
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Currently we don't support viewing of dwg, dxf, or ipt files.
The recognized file formats can be found here
https://cad.onshape.com/help/#export.htm
edit: my mistake, we do accept .ipt files.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
