DWG Never Stops Loading
famadorian
Member Posts: 390 ✭✭✭
I've had this DWG shared to me:
https://cad.onshape.com/documents/34bf3bd45c956d9deef89986/w/b475b00c3e1894587b4c1515/e/2adbd0ed432e1cc3f7b8d4b0
1. It never stops loading
2. It's almost impossible to make a copy of it, because the interface is not separated from the core, so it takes 10 minutes to make a copy.
3. Once I've made a copy, I struggle equally to share it again because the interface is not responding.
25MB for a DWG file is big. I did manage to open it in both the DWG viewer and by converting it to an Onshape drawing but it did take some time. However, you can copy and share no problem since the UI is disconnected from the modeling servers.Senior Director, Technical Services, EMEA0
You're layout is beefy
It even lags while panning in a full seat of AutoCAD 2018. I purged the filed and re-uploaded it. It is half the file size.
Still takes a long time to open. I think you may have hit the upper limit...
https://cad.onshape.com/documents/f875c07a36ba51d09c83f18d/w/56ae02c800f8ad4c4015747e/e/40dbb9a48fc236152666da26
john_mcclary said:You're layout is beefy
Upper limit? This is one floor of a private house;) How would a skyscrape do it?
Anyways, when loaded into Autodesk Online Viewer, it loads in 0.1 second and there's no lag, at all
https://autode.sk/2YokC7r
Really? This is what I got from clicking the link:
Senior Director, Technical Services, EMEA0 -
@NeilCooke
It was working yesterday.0
