Can't get a single loft to have rotational symmetry with other lofts
robert_jacobs467robert_jacobs467 Member Posts: 2
edited August 2019 in Using Onshape
-edit- after playing around a little more, I realized I had two misaligned errors that were masking my real problem. The loft is now fixed.
I am lofting an x shape to a center square, and for some reason one of the lofts from the corner will not evenly align with the other 3 along the y axis. I tried to align by vertex, but that makes the x axis loose alignment. I've tripple checked that my sketches have symmetry and that lofts 2-4 are properly centered.  Are there any recommendations for how to square things up? my goal is to have the centering between loft 3  and 5 be the same as between loft 2 and 4 without the triangle between loft 5 and 2 going out of alignment.
Its part studio 2 in case the share tab doesnt go right to it.  If I need to put any more information let me knop
