Names of parts with parameters values inside
otaolafr
Member Posts: 113 EDU
hello,
is it possible to use a parameter from features or a parameter from a configuration to being use in the name of the part in a way that changes automatically?
for E.G i have #D=5cm that i use to define the length of a circle in a sketch that i extrude with a #H=15cm, i would like that the part is called for example "tube of 5cm of diam and 15cm of high" and that if i change the values of #D and #H their values changes in the name of the part. #D=2cm #H=20cm will result in a part with the name "tube of 2cm of diam and 20cm of high"
also as i think is in the same subject, is it possible to use these parameters in notes or tables in drawings? thanks
https://cad.onshape.com/documents/67e94d9f28bea28acfe4cd2f/w/148839604556a1f380541be8/e/6390c076d48caa89151017d9
but i had a problem, @kons@konstantin_shiriazdanov it doesnt modify the name of the part
in the secont entry i put it "toString(#DE)" without the ".
the part still has the same name SUPPORT BLOCKER
https://forum.onshape.com/discussion/comment/46448#Comment_46448
thanks
i wanted to use that "name" to use it in the FS to configure name. i solved by adding a variable that is a string with the same name as the name of the list of the configuration, and configurated to change with the configuration. but i wanted to know if there was a directly way to used. but thanks anyway
I was doing a custom icon for a FS and I thought about reaching you, I made a simple loop icon with the color scheme of other icons for property explorer, I could send you the .svg if you want to add it to the FS
I could modify it too if you dont like it (and send you the inkscape file too)
there we are
