For (var i = .. Sketch and Plane and Circular pattern
Fda
Member Posts: 42 ✭✭
How could you create a with a "for (var i = ...." a Sketch in each plane.
And how Extrude each Sketch.
jhljlñkjñl
jhljlñkjñl
var sketch2 = newSketch(context, id + "sketch2", {
"sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
for (var i = 0; i < 5; i += 1)
var miPlane is string = "plane" ~ i;
var Circle is string = "Circle" ~ i;
skCircle(sketch2, miPlane, {
"center" : vector(i, 0) * inch,
"radius" : 1 * inch
opPlane(context, id + miPlane, {
"plane" : plane(vector(0, 0, i) * inch, vector(0, 0, 1)),
"width" : 6 * inch,
"height" : 6 * inch
// Create sketch entities here
skSolve(sketch2);
Making one extrude then using opPattern would be more efficient.Senior Director, Technical Services, EMEA0
@fermin_fermin_1
@billy2 did something like this a while ago: https://forum.onshape.com/discussion/2568/showing-whats-in-a-query
annotation { "Feature Type Name" : "Star" } export const star = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type annotation { "Name" : "length" } isLength(definition.length, LENGTH_BOUNDS); annotation { "Name" : "radius" } isLength(definition.radius, LENGTH_BOUNDS); annotation { "Name" : "count" } isInteger(definition.count, POSITIVE_COUNT_BOUNDS); } { ///======================================================================= ///================ https://forum.onshape.com/discussion/2568/showing-whats-in-a-query var ang = 360 / definition.count * degree; var i; var j; var k; for (var cnt = 1; cnt <= definition.count; cnt += 1) { i = cos(ang * cnt); j = sin(ang * cnt); debug(context, ang * cnt / degree); fCylinder(context, id + "cylinder" + cnt, { "bottomCenter" : vector(0, 0, 0) * meter, "topCenter" : vector(i, j, 0) * definition.length, "radius" : definition.radius }); debug(context, (qContainsPoint(qCreatedBy(id + "cylinder" + cnt, EntityType.FACE), vector(i, j, 50) * definition.length))); } ///================ https://forum.onshape.com/discussion/2568/showing-whats-in-a-query ///======================================================================= //######################################################################## //https://forum.onshape.com/discussion/comment/38253#Comment_38253 const allCuboids = qUnion([qCreatedBy(id + "cylinder", EntityType.BODY), qCreatedBy(id + "cuboidGroupB", EntityType.BODY)]); opBoolean(context, id + "boolean1", { "tools" : allCuboids, "operationType" : BooleanOperationType.UNION }); opTransform(context, id + "transform2", { "bodies" : allCuboids, "transform" : transform(vector(1, 2, 50) * millimeter) }); //https://forum.onshape.com/discussion/comment/38253#Comment_38253 //######################################################################## }, { /* default parameters */ });Sorry for a delay in answering. This is wanted0 -
annotation { "Feature Type Name" : "opPattern" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type } { // Define the function's action var sketch1 = newSketch(context, id + "sketch1", { "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE) }); skCircle(sketch1, "circle1", { "center" : vector(0, 0) * millimeter, "radius" : 1 * millimeter }); skSolve(sketch1); extrude(context, id + "extrude1", { "entities" : qSketchRegion(id + "sketch1"), "endBound" : BoundingType.BLIND, "depth" : -100 * millimeter }); ///========= AXIS var sketch2 = newSketch(context, id + "sketch2", { "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE) }); skCircle(sketch2, "circle2", { "center" : vector(0, 0) * millimeter, "radius" : 1 * millimeter }); skSolve(sketch2); ///========= AXIS var miBox = qCreatedBy(id + "extrude1", EntityType.BODY); opPattern(context, id + "pattern1", { "entities" : entities, //?????? "transforms" : transforms,//?????? "instanceNames" : instanceNames//?????? }); });
Please could you give a complete example with a code, perhaps more users will help you with the operation of "opPattern".NeilCooke said:Making one extrude then using opPattern would be more efficient.
@fermin_fermin_1
opPattern documentation:
https://cad.onshape.com/FsDoc/library.html#opPattern-Context-Id-map
Just typing this up directly on the forum, so there may be some slight typos, but the general idea is:const lineToRotateAround = line(WORLD_ORIGIN, Z_DIRECTION); const angleIncrement = (360 * degree) / definition.count; var transforms = []; var instanceNames = []; for (var i = 1; i < definition.count; i += 1) // Iterate from 1 -> (definition.count - 1) because we have already created the base (0) instance { const currAngle = i * angleIncrement; const currTransform = rotationAround(lineToRotateAround, i * angleIncrement); // Append the currTransform to the transforms list transforms = append(transforms, currTransform); // instance names don't matter, they just need to be unique strings instanceNames = append(instanceNames, toString(i)); } const patternId = id + "pattern"; opPattern(context, patternId, { "entities" : qCreatedBy(originExtrudeId, EntityType.BODY), "transforms" : transforms, "instanceNames" : instanceNames }); const booleanId = id + "boolean"; opBoolean(context, booleanId, { "tools" : qUnion([qCreatedBy(originalExtrudeId, EntityType.BODY), qCreatedBy(patternId, EntityType.BODY)]), "operationType" : BooleanOperationType.UNION });
Hope this helps. Feel free to comment back with questions.Jake Rosenfeld - Modeling Team0 -
Jake_Rosenfeld said:@fermin_fermin_1
Hope this helps. Feel free to comment back with questions.var sketch1 = newSketch(context, id + "sketch1", { "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE) }); skCircle(sketch1, "circle1", { "center" : vector(0, 0) * millimeter, "radius" : 1 * millimeter }); skSolve(sketch1); extrude(context, id + "extrude1", { "entities" : qSketchRegion(id + "sketch1"), "endBound" : BoundingType.BLIND, "depth" : -100 * millimeter }); var originExtrudeId = qCreatedBy(id + "extrude1", EntityType.FACE);// originExtrudeId ??????? var MyCount = 5; const lineToRotateAround = line(WORLD_ORIGIN, Z_DIRECTION); const angleIncrement = (360 * degree) / MyCount; var transforms = []; var instanceNames = []; //definition.count -> MyCount for (var i = 1; i < MyCount; i += 1) // Iterar de 1 -> (definition.count - 1) porque ya hemos creado la instancia base (0) { const currAngle = i * angleIncrement; const currTransform = rotationAround(lineToRotateAround, i * angleIncrement); // Añadir currTransform a la lista de transformaciones transforms = append(transforms, currTransform); // los nombres de instancia no importan, solo deben ser cadenas únicas instanceNames = append(instanceNames, toString(i)); } const patternId = id + "pattern"; opPattern(context, patternId, { "entities" : qCreatedBy(originExtrudeId, EntityType.BODY), "transforms" : transforms, "instanceNames" : instanceNames }); const booleanId = id + "boolean"; opBoolean(context, booleanId, { "tools" : qUnion([qCreatedBy(originalExtrudeId, //variable originalExtrudeId not found EntityType.BODY), qCreatedBy(patternId, EntityType.BODY)]), "operationType" : BooleanOperationType.UNION }); });it's wrong? :'(
@fermin_fermin_1
You should usevar <b>originExtrudeId</b> = id + "extrude1";
where you hadvar originExtrudeId = qCreatedBy(id + "extrude1", EntityType.FACE);// originExtrudeId ???????
and leave the rest of the code the same.1 -
@fermin_fermin_1
The reason it is saying "variable originalExtrudeId not found" is because you are trying to use the variable "originalExtrudeId", and earlier you declared it as "var originExtrudeId = ...". These two names aren't the same.
Otherwise, @MBartlett21 is correct:const originalExtrudeId = id + "extrude"; opExtrude(context, originalExtrudeId, { ... }); ... const patternId = id + "pattern"; opPattern(context, patternId, { "entities" : qCreatedBy(originalExtrudeId, EntityType.BODY) });
@Jake_RosenfeldJake_Rosenfeld said:These two names aren't the same.
That is exactly what I didn't notice.
I thought that his feature was failing because it would have beenqCreatedBy(qCreatedBy(id + "extrude", EntityType.FACE), EntityType.BODY)0 -
Thank you very much MBartlett21MBartlett21 said:@fermin_fermin_1
and leave the rest of the code the same.annotation { "Feature Type Name" : "My opPattern" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type } { // Define the function's action var sketch1 = newSketch(context, id + "sketch1", { "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE) }); skCircle(sketch1, "circle1", { "center" : vector(0, 0) * millimeter, "radius" : 1 * millimeter }); skSolve(sketch1); extrude(context, id + "extrude1", { "entities" : qSketchRegion(id + "sketch1"), "endBound" : BoundingType.BLIND, "depth" : -100 * millimeter }); var originExtrudeId = id + "extrude1"; var MyCount = 5; const lineToRotateAround = line(WORLD_ORIGIN, Z_DIRECTION); const angleIncrement = (360 * degree) / MyCount; var transforms = []; var instanceNames = []; //definition.count -> MyCount for (var i = 1; i < MyCount; i += 1) // Iterate from 1 -> (definition.count - 1) because we have already created the base (0) instance { const currAngle = i * angleIncrement; const currTransform = rotationAround(lineToRotateAround, i * angleIncrement); // Append the currTransform to the transforms list transforms = append(transforms, currTransform); // instance names don't matter, they just need to be unique strings instanceNames = append(instanceNames, toString(i)); } var patternId = id + "pattern"; opPattern(context, patternId, { "entities" : qCreatedBy(originExtrudeId, EntityType.BODY), "transforms" : transforms, "instanceNames" : instanceNames }); //// boolean part const My_opPattern = qUnion([qCreatedBy(id + "pattern", EntityType.BODY), qCreatedBy(id + "extrude1", EntityType.BODY)]); const booleanId = id + "boolean"; opBoolean(context, booleanId, { "tools" : My_opPattern, "operationType" : BooleanOperationType.UNION }); });
