How to simplify the assembly?
miczech
                    Member Posts: 8 PRO
                    Hello all,
so, pretty soon after starting using Onshape I have encountered this problem:
I uploaded a model I want to use in another assembly but then, whole document is just too big for Onshape to work fluently. I am not focused on that heavy design I have just uploaded, I am just interested in shape/volume/boarder dimensions. Usually I would have two possibilities:
1st: create very schematic, simply shaped, 3D, 1 part draft of the piece I am interested in,
2nd and quite often used when the more detailed shape is needed: create multi-body, one part document. it is light and it has the exact shape of original assembly.
I understand in Onshape it can be performed with boolean feature?
And here comes my problem:
Apparently Onshape will only allow me to make the "union" if there is a contact between parts. In other words, my assembly includes 277 parts but "union" will work, in my case, only for 222 of them as the rest is "floating" (there is e.g. 0.5mm distance between parts).
What should I do?
Am I using correct feature? Or are there any other which will allow me to "thin-up" and simplify the assembly?
Thank you in advance for your help. I hope I described my problem clearly enough for you to understand.
What should I do?
There is also a feature you can use called Fix PCB, intended to do almost the same thing you are looking for https://cad.onshape.com/documents/9a9b81d17d4b69e58ad9b0b0/v/c253688ad8add5efd222a709/e/3152191074466a8b45231663#_ga=2.170399136.1436770626.1565010688-1407455194.1565010688
Although, I am a bit surprised it is not basic feature in Onshape as from my perspective this type of operation is not something very uncommon.
Thank you again!
example: I have a PCB with 200+ parts, where making simplified model is not a problem using Fix PCB. At the same time, there is 3000+ surfaces in the same PCB and clearly, Fix PCB won't work on it (as any other operations). Grouping and packing into sub assemblies solves the problem only superficially as it looks nice on the ladder but Onshape still has to operate the document with 3k+ elements.
In that case I have just took a volume of the pieces and created simplified block myself as it is the fastest "solution" I came up with.
@mlaflecheCAD would you have any suggestions? I know that the problem is on the design side as surfaces in general cause problems and in that case i should have received assembly with solid parts.
regards,
