Drawn Metal Cup with Vents
I am attempting to draw vents on an aluminum can similar to the attached image. The can itself is drawn aluminum, but from what I understand the best I can do in OnShape is use a regular Sheet Metal drawing of an incomplete cylinder (with a slit down the side to allow "unfolding"). Overlooking the inability to model drawn metal, manufacturers have described the vent itself as "stamped", but I am not seeing an effective way to model this in OnShape. I have attempted bending and creating a tab, but both will not convert correctly. Any ideas on how this should be modeled in OnShape? Thanks!
mlaflecheCAD
Member, Onshape Employees, Developers Posts: 198
@sean_hart For this design, with it having compound formed features for the cylinder and the vents, it would be best to model this using non-sheet metal modeling techniques. This would be the case in most CAD programs out there because of the stamped features on the rolled portion of the design.Regards,Mike LaFleche @mlaflecheCAD1 -
steve_shubin
Member Posts: 1,118 ✭✭✭✭
@sean_hart
If you step through the features list in this document, it will show you how to make vents
https://cad.onshape.com/documents/187e858549592a9f394110b2/w/44156a98c0a7d45f9a82882f/e/916f879d0ed191223b221c31
1
