How to move a part using BodyType.MATE_CONNECTOR
Fda
Fda Posts: 42 ✭✭
edited August 2019 in FeatureScript
How can I move the cube to the end of the cylinder?
annotation { "Feature Type Name" : "Transform" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        // Define the parameters of the feature type
        annotation { "Name" : "My Query", "Filter" : BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
        definition.FaceConnector is Query;
        // Define the function's action
        //We create a solid (part) from a sketch
        var sketch1 = newSketch(context, id + "sketch1", {
                "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
        skCircle(sketch1, "circle1", {
                    "center" : vector(0, 0) * millimeter,
                    "radius" : 25 * millimeter
        // Create sketch entities here
        skSolve(sketch1);
        extrude(context, id + "extrude1", {
                    "entities" : qSketchRegion(id + "sketch1"),
                    "endBound" : BoundingType.SYMMETRIC,
                    "depth" : 100 * millimeter
        // We create a Mate Connector in part
        // what do we want to move
        var origin = vector(0, 0, 0) * millimeter;
        var com = evApproximateCentroid(context, {
                "entities" : definition.FaceConnector
        var csys = coordSystem(com, vector([1, 0, 0]), vector([0, 0, 1]));
        opMateConnector(context, id + "com", {
                    "coordSystem" : csys,
                    "owner" : definition.FaceConnector
        /*How do I change "extrude1" for definition.FaceConnector */ /// ??????
        var myPart = qCreatedBy(id + "extrude1", EntityType.BODY); // ????
        var My_vector = toWorld(evMateConnector(context, {
                    "mateConnector" : definition.FaceConnector
        opTransform(context, id + "transform1", {
                    "bodies" : myPart,
                    //"transform" : transform(vector(1, 2, 0.5) * inch)
                    "transform" : My_vector
           // We delete the sketch
           opDeleteBodies(context, id + "deleteBodies1", {
           "entities" : qUnion([qCreatedBy(id + "sketch1"), qCreatedBy(id + "sketch1")])
           // Boolean Operation Type UNION
           var PartAndHex = qUnion([qCreatedBy(id + "extrude1", EntityType.BODY)]);
           opBoolean(context, id + "BooleanUnion", {
           "tools" : PartAndHex,
           "operationType" : BooleanOperationType.UNION
  • @Fda
    I am going to assume that what you want is to move the cylinder that you extruded to be build right on top of the mate connector?  If not, then I may need additional detail.  Instead of using a transform, I would just make the cylinder where you want it in the first place:
    const mateConnectorCSys = evMateConnector(context, { "mateConnector" : definition.FaceConnector });
    const mateConnectorAsPlane = plane(mateConnectorCsys);
    const sketchId = id + "sketch";
    var sketch = newSketchOnPlane(context, sketchId, mateConnectorAsPlane);
    // Now we are sketching directly on the coordinate system defined by the mate connector
    do any sketching you want
    // It is usually better to use opExtrude (operation) rather than extrude (feature).
    const extrudeId = id + "extrude";
    opExtrude(context, extrudeId, {
        "entities" : qSketchRegion(sketchId),
        "direction" : mateConnectorCSys.zAxis,
        "endBound" : BoundingType.BLIND,
        "endDepth" : 100 * millimeter
    // Now delete the sketch and you should be done.
    Just for the sake of completeness, if you do want to move something from one place to another, you could do it like this:
    const moveFrom = coordSystem(vector(0, 0, 0) * inch, vector(1, 0, 0), vector(0, 0, 1)); // or any other coordinate system that you want to use as a "base"
    const moveTo = evMateConnector(context, { "mateConnector" : definition.FaceConnector });
    opTransform(context, id + "transform", {
        "bodies" : someQueryForBodiesToMove,
        "transform" : toWorld(moveTo) * fromWorld(moveFrom)
  • Fda
    Fda Posts: 42 ✭✭
    edited August 2019
    @Fda
    I want
    - select a solid
    - move the solid to a vector that I already know. It's the sketch
    something like this
    annotation { "Feature Type Name" : "My Mate" }
        precondition
            annotation { "Name" : "My Query", "Filter" : BodyType.MATE_CONNECTOR && EntityType.BODY , "MaxNumberOfPicks" : 1 }
            var myBody = definition.FaceConnector; ////  ??????
                        "bodies" :  myBody,
  • Jake_Rosenfeld
    Jake_Rosenfeld Posts: 1,646 image
    edited August 2019
    @Fda
    First:
    If you are moving parts "from" the selected mate connector "to" the origin, you'll have to switch "moveFrom" and "moveTo".  The mate connector is "moveFrom" and the origin is "moveTo".
    Second:
    The mate connector is not actually associated with the body that you clicked on to create it in any way that is easy to pull out of FeatureScript.
    The most direct way to approach this would be to just add a:
    annotation { "Name" : "Bodies to move", "Filter" : EntityType.BODY }
    definition.bodiesToMove is Query;
    to the precondition, and make your user select the bodies they want to move.
    Another way of doing it which does not rely on the user selecting the bodies they want to move, but does rely on the mate connector touching the body, and may end up moving bodies that you don't want to move, could be the following:
    const myBody = qContainsPoint(qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), moveFrom.origin);
  • Fda
    Fda Posts: 42 ✭✭
    @Fda
    First:
    Second:
    Person who responds late, as can be done with just one
    ### annotation {} is Query ### one click
    -Without moving the planes
    -Without moving the origin.
        precondition
                    annotation { "Name" : "My Query", "Filter" : BodyType.MATE_CONNECTOR  , "MaxNumberOfPicks" : 1 }
                        "bodies" : myBody,
  • @Fda
    You do not need both the `definition.bodiesToMove` and the `myBody = qContainsPoint(...)` code. As of right now, your `definition.bodiesToMove` parameter is not used anywhere, and does not do anything.
    Either take the bodies to move as a parameter, so that the user must click on the exact bodies they want to move:
        precondition
                        "bodies" : definition.bodiesToMove,
    Or do not make the user select the bodies they want to move, and make an educated guess based on the position of the mate connector:
        precondition
                        "bodies" : myBody,
        <span>});</span>
  • @Fda
    Habla Español?  Tenemos hispanohablantes aquí si quiere preguntarnos en Español.
  • @Fda
    Is this how you expect it to work:
    https://cad.onshape.com/documents/1002ce69245ea445611e4980/w/f52429a498b020c73540b506/e/08e27852c7e1888489504652
    I did a couple things:
    1) I switched `moveFrom` and `moveTo` (as I mentioned a few comments up, but forgot to do when I copy-pasted your examples later)
    2) I added a qSketchFilter in "B" to stop the sketches from moving.
    3 ) I deleted C and D, since A and B represent the two options I am trying to show you.
  • Fda
    Fda Posts: 42 ✭✭
    @Fda
    I would like that when I put a mate Mate connector
    annotation {"Name": "My Query", "Filter": BodyType.MATE_CONNECTOR, "MaxNumberOfPicks": 1} definition.FaceConnector is Query;
    I made a query of the body to which the face belongs in placed the Mate connector.
    Avoiding having to do
    annotation {"Name": "My Query", "Filter": BodyType.MATE_CONNECTOR, "MaxNumberOfPicks": 1} definition.FaceConnector is Query; annotation {"Name": "My Query", "Filter": BodyType.MATE_CONNECTOR, "MaxNumberOfPicks": 1}
    this way to move the body with a single mouse OfPicks (clicks)
  • @Fda
    In the example I shared back to you ( https://cad.onshape.com/documents/1002ce69245ea445611e4980/w/f52429a498b020c73540b506/e/08e27852c7e1888489504652 ), The "My Mate (B)" feature does what you are asking for:
  • Fda
    Fda Posts: 42 ✭✭
    edited September 2019
    Wonderful
    annotation { "Feature Type Name" : "My Mate (B)" }
        precondition
        var moveTo = coordSystem(vector(0, 0, 0) * inch, vector(1, 0, 0), vector(0, 90, 0));
        const moveFrom = evMateConnector(context, { "mateConnector" : definition.bodiesToMove });
        var myBody_Transform = qContainsPoint(qConstructionFilter(qSketchFilter(qEverything(EntityType.BODY), SketchObject.NO), ConstructionObject.NO), moveFrom.origin);
                    "bodies" : myBody_Transform,
