Creation of individual DRW views and choosing the view reference plane
If I have a lot of parts in 3D Design the orientation of them is sometimes not perpendicular aligned to the origin Planes. That leads to views on the Drawing which you can not use for making a proper DRW. The view you can create is always oriented on the main planes and then on the DRW you get more ore less kind of unwanted isometric views for such parts. In the DRW you can change at least the angle of on degree of freedom but not for more. Any Idea what I can do? Is there a way I don't know? From Catia for example I know you can choose the view plain you prefer from 3D before the view creation.
Thanks a lot!
Thanks a lot!
https://cad.onshape.com/documents/a41e3fbb39080eaf5752246f/w/74fe1499c8580c2c2f912b88/e/4e6d3ef6d785732b9b8b1def
