opSplitFace - Invalid Input
I hoping someone can explain to me why this script is failing:
Ultimately this is to be part of a more complicated script. I wrote this simple script to troubleshoot and apparently I don't understand what opSplitFace is expecting for "faceTargets" and "bodyTools". I've tried to specify the input faces a few different ways but haven't had any success yet.
lana Onshape Employees Posts: 741
"bodyTools" name suggests that bodies are expected, but you are supplying faces. If you want to be selecting faces as tools, you can useopExtractSurface() to create a sheet body coincident with the face.
6
"faceTargets" : targetFace,
"bodyTools" : qCreatedBy(id + "extract", EntityType.BODY)
Instead of extracting you can actually use the "faceTools" field into opSplitFace rather than the "bodyTools" field. I'll have to go update that documentation too...
