Grant Approval problem
yakhoub_ndiaye
Member Posts: 3 EDU
Hi, Im a Mac user. When connecting my OnShape CAD file to Matlab, I received this error code:
Grant Approved
Please copy this code, switch to your application and paste it there
How to deal with this. In advance I thank you for your help
yakhoub_ndiaye
Member Posts: 3 EDU
Hi Bradley, as you said it was on the MathWorks side. I've found a solution following this linkhttps://fr.mathworks.com/support/bugreports/details/1974098Thank.0
For some more information, here is our blog on our connection with simulink: https://www.onshape.com/cad-blog/partner-spotlight-simscape-delivers-the-magic-of-testing-designs-without-hardware
And here is the documentation from MathWorks:
https://www.mathworks.com/products/simmechanics/onshape.html
https://www.mathworks.com/help/physmod/sm/ug/onshape-import.html
Let us know how this works out!
Twitter: @bradleysauln
I've looked at the docs and run many time but the problem still remains. I've run the command using < smexportonshape >:
