Move context
fma
Member Posts: 87 ✭✭
Hi!
Is there a way to move/realign a context while editing a part in-context?
Thanks,
Frederic
Depending on what you want, you can either update the context you are looking at, or create a new second context to model off of. The steps involved would be to get the assembly into the new position that you want, and then create the new context or update the existing context from there. Instructions are here:
https://cad.onshape.com/help/Content/in-context.htm
It sounds like the confusion might be caused by context in part studio being oriented differently from assembly. If the part you want to edit is inserted in the assembly transformed (e.g. flipped up side down), then the context in the part studio would appear transformed (flipped up side down in this case). That is because in the part studio everything is rendered in the coordinates of that part studio.
