Move Boundary -problem selecting surface boundary
bruce_williamsbruce_williams Member, Developers Posts: 842 EDU
Great feature for surface work!
I just ran into a challenge and want to share the solution.  I offset a part surface by 0 to work with it, then could not directly select that surface boundary edge.  Two solutions - 'Select Other (~ key)'  or hide the part so only surfaces show.
www.accuratepattern.com
    @bruce_williams Looks like a bug to me! Reported.
    edited September 2019
    update - Onshape has pushed a fix for this.  Works as expected now letting you select a boundary from surface with 0 offset.  Thanks team Onshape!
