Featurescript-Vector rounding
Hugh_Goodbody
Member Posts: 41 PRO
I am computing the dot product of some vectors to check for parallelism. I have run into a rounding error situation. What is the best way to round the vectors so that the values of the highlighted ones are the same?
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
if checking parallelism is the only aim you can use parallelVectors() function from standard libraryparallelVectors (vector1 is Vector, vector2 is Vector) returns boolean
Returns true if two vectors are parallel (within tolerance).
10
https://cad.onshape.com/FsDoc/library.html#ValueWithUnits
Onshape, Inc.
