Revisions & Configurations inside of Assemblies
When you have an assembly and you make it configurable, you can configure one of your models inside of the assembly that is also configured. For example, we have a tube configuration that is used in multiple locations in a model, and we configure in the assembly which tube configuration appears depending on the options we select from the table. It's a very powerful tool when dealing with configured assemblies.
However, we have hit a bit of a snag. We want to use, going forward, released models when making our assemblies. Because each end product tends to be very customized per customer, we want to make a template document where we start with the basic structure, copy-work-space, and then make changes as needed under the new part number. Having this template would standardize our process (something we couldn't do at all with SolidWorks, because it'd crash on us almost constantly or the configurations would explode on us) and it would make it so we already have 75% of the work done before we even start. These templates are very much doable...with versions.
The moment we try to use released models, we cannot configure them. The only option given is whether it is suppressed or un-suppressed.
My question to the community and Onshape is was this an intentional feature when it comes to releases? I'm asking before I submit an improvement request because I want to understand what led to how its structured right now, whether it is intentional or a "we haven't gotten to it yet" thing (which I completely understand). I just feel that it is disconnected from how Onshape normally handles configurations in assemblies with a blanket absence of that feature once released. If the mindset is "Once released, it shouldn't change unless revised", I understand where that comes from. However, with configurations, you have multiple releases tied to the model. I just would like the option of at least choosing which release to use inside of that model, rather than a disconnect of "you can't change it" once inserted into the assembly.
Thank you for your time
Your observations are correct - the explanation is as follows:
Unlike SolidWorks, individual configurations can be released.
At any time, you are free to reference a released object (representing a single state (configuration)) OR the configurable workspace of the part.
The reason you cannot do 'both' is that they are contradictory - a released part is one that (by definition) cannot change and a workspace contains NO released objects because a workspace is for change.
Your options today are one or the other. The only downside to using the (configurable) workspace is that every time the assembly is released, that configuration gets revisioned over and over. For THAT we are working on something
