Mirroring imported image in sketch mode
tony_459tony_459 Member Posts: 206 ✭✭✭
edited April 2019 in Drawings
How does one do it? I can't use the mirror feature directly on an image, and if I use it on the dashed lines that surround my reference image, only those lines are mirrored. I can't specify a negative width or height to invert the image. Rotating the sketch plane by 180 degrees doesn't work. Thanks for helping.
