Why does Branch request to update feature library?
Lately every time I branch a work space I get this message
Can someone explain what this really means?
What functionality is being added?
Doesn't Onshape auto-update in the background?
How long does this usually take?
Is it dependent on the size of the document? (tab count / part count)
It says I cannot access the doc, but I can (hope it didn't break it). I backed out of it and keep refreshing the main page waiting for this icon to go away.
Stuff like this is usually quick with Onshape, so I'm wondering why it is taking so long, etc..
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    Ah, so it is because the version was older..
    but it was doing it to versions that happen seconds earlier
  • MBartlett21
    MBartlett21 Posts: 2,064 ✭✭✭✭✭
    @john_mcclary
    I think that maybe it had tried to update the workspace, but couldn't and was stuck at an earlier version. Maybe ask @NeilCooke about it?
  • NeilCooke
    NeilCooke Posts: 6,097 image
    @john_mcclary - that is an odd one, especially on a brand new doc. The standard library has not been updated since Oct 17th so it shouldn't ask to update. Even using old custom features should not ask for an update.
    Anyway, as @MBartlett21 says "You shouldn't need to worry about it and you can just choose 'Later' if you want."
    Was the doc created from the "create" button or did you copy it from a template doc you may have? That would explain requiring the update.
    Let us know if it happens again.
  • john_mcclary
    It is indeed a copy of a document, but it was copied from my most recent branch that "should" have been "up-to-date" right?
  • john_mcclary
    Yea, it's showing 1150 in the branch I copied. (which is my working branch)
    and it is showing 1174 in the "main" branch
    Looks like you don't update branches?
  • NeilCooke
    Branches do get upgraded, but perhaps an issue was found - one way to find out is to let Onshape upgrade the branch, then once the clock icon has disappeared from the Docs page is to go back and "Show code" again to see if the number has changed.
  • john_mcclary
    Thanks for the deeper dive
  • MBartlett21
    @Jake_Rosenfeld
    Is there any way, as a user, to 'force' an upgrade, even if it breaks things?
  • @MBartlett21
    If you roll back to the feature, suppress it, and recreate the same feature with the same parameters, you are essentially forcing the held back feature to update.  It may break downstream references though.  The other way is to contact support and get us to do it :)
    There is not really any way to force a braking workspace update, but really those should be really rare and its more common to see an upgraded workspace with a bunch of held-back features.
  • MBartlett21
    @MBartlett21
    @Jake_Rosenfeld
    The trouble with recreating it is the recreation has a new id and also it is often a lot of work (e.g updating a sketch)
  • john_mcclary
    Not only that, how do you know which feature caused the update to fail
  • MBartlett21
    @john_mcclary
    If you choose to view code in the part studio and some features are held back, they are called with an "asVersion" parameter with the version that they were held back to.
