Improvements to Onshape - November 12th, 2019
13»
    Thanks @owen_sparks
    s/b fixed now
    www.accuratepattern.com
  • Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
    Thanks for new updates!  Noticed a slight niggle with the new instances/mates list.  The scroll bar keeps appearing directly over the hide/show icon for a part (see screenshot).  I've tried re-sizing the list but it keeps happening.  And causes the list to jump about rather than hide/show.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,066 image
    I can't reproduce this on any browser on Mac - what is your set up?
    If you are using a Mac, this is caused by having "Show scroll bars" set to "When scrolling". You can prevent this by setting it to Automatic. We'll take a look to see if it is possible to change this behaviour.
  • francois_bouletfrancois_boulet Member Posts: 65 ✭✭✭
    Thumbs up for: Break a Section view in Onshape Drawings.
    Any improvements in Drawings is welcomed.
    Thanks to the team !
    La simplicité est la sophistication suprême.
    Léonard de Vinci
  • sam_hollandsam_holland Member Posts: 21 PRO
    Great updates! I'm already using composite parts and loving it. However, I think RealityServer fails to see composite parts and I cannot render them out
    @paul_arden do yo know about this?
    edited November 2019
    We can now sort custom features in a toolbar!
    EDIT: Now it has disappeared :(
  • Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 228 image
    Yes, we are aware of the issue and have been working with Onshape on it.
    We rolled out a fix for Composite parts last week. They will now correctly show up in Assemblies and Part Studios. Note that they will always show up as Closed, so the constituent parts are not shown separately in the scene graph. As with access to part faces you can right click in the scene graph and select the Reveal option to show everything.
  • MichaelPascoeMichaelPascoe Member Posts: 2,898 PRO
    This is an old post, but Composite parts have saved me so much time. Thanks Onshape team!
    RENDERCAD
