Cannot loft surfaces: self-intersecting
gauthier_östervall
Member Posts: 99 ✭✭
in Drawings
Here is my project.
https://cad.onshape.com/documents/3201ed6d638fbda0a92b317f/w/b627c23f583486323569fbf4/e/b262f99b42d19b69dc47236c
I am trying till fill in the gap between the grey and the blue part, before merging them together:
I was hoping to loft the thin face of blue that is facing towards grey, and the corresponding face of grey. Unfortunately, that would give me a self-intersecting loft, or so does onshape say.
These faces have very similar shapes, same number of edges and vertices, they are also at a slight angle.
What I believe makes things difficult is that they touch at their end:
No interference, though.
I can add many (well, 12) surface lofts, but would like to know how to create the solid loft although the surfaces are touching.
This is doing it with surface lofts:
Although I'm going to need to do that for all parts, and to keep the chamfer minimal I'll have to test values manually every time.
Any other idea? I've tried Fill surfaces but failed, and it seemed more cumbersome anyway.
I extruded the blue part to the gray. This is a simple way to merge the parts.
see example here
I am attempting to build an ergonomic keyboard, like the Dactyl but actually more inspired by the Kinesis Advantage. Only with my own angles.
I have since decided to use a simplified model of the switch part, and use boolean to make the holes into a thicker part. Here. I'm actually having troubles merging parts right now, which is nice since I would have missed your reply otherwise
