Modification of publically configurable assemblies
LordPeachesLordPeaches Member Posts: 2 EDU
Hello, I am using an assembly available under 'Public' on OnShape, but I need to make a slight modification that is unique to my own assembly. Is there any way to copy this assembly so I can make my own modifications to it? How can I do this without having to download the document, reupload it, and redo all the mates? Thank you.
  • HakroHakro Member Posts: 67 ✭✭✭
    edited December 2019
    You can make a copy from public documents and then edit the assembly ...
