Multiface STL File export
kai_h_borbekai_h_borbe Member Posts: 14 EDU
Hey,
is it possbile on OnShape to export a multiface STL File, i need it for SnappyHexMesh or cfMesh.
Without the multiface, the complete surface is summarized to one patch.
Best regards
Kai
    Hi kai_h_borbe,
    Can you give an example of a file (or files), preferably as a text STL, that you are hoping to have the output as.  As far as I understand, STLs should only have one body in it which is how our exports to STL work.  If I understand better the output, I could possibly come up with a solution while we investigate a native solution for this.
    Jake Ramsley
