mates in part studio
Hey, im trying to make parts combine into one part in parts studio, is that possible ?
    @kasper_leth_rasmussen
    As long as the parts occupy overlapping space (no gaps) you can very simply achieve this using "Boolean", select the "Union" option, and pick the parts you want to join
  • clayton_ertleyclayton_ertley Member Posts: 58 ✭✭
    You may need to be more specific. Are you trying to join into a single part of are you trying to make one dependent on the other(like if you move one, the other moves with it)?
  • kasper_leth_rasmussenkasper_leth_rasmussen Member Posts: 3
    I would like to join it all in to one part!
