How to design a sword blade
oh_grapes
Member Posts: 1 ✭
Hello everyone! I am working on the Elucidator from Sword Art Online and im having trouble making the blade.
Probably very simple to figure out, but I am very new to this.
Thanks!
Thanks!
I made this a long time ago for another user. Hope this helps!
https://cad.onshape.com/documents/c445a2a98e822aa0e6d524ac/w/e6ec8c754244ce6857b78a3e/e/cd4992999a933e1d50ad8702
@wyliam_luce Why did you have to choose the Master Sword? If it were any other sword I simply would have directed you to the Onshape learing center. However, as a Zelda fan, and Onshape fan, I'm obligated to take this to the next level!
To make something like the Master Sword, you will need to learn Onshape. The best way to do that is with the self paced tutorials found here: Onshape Self Paced Courses
A model like this will most likely use the following features:
Here is a quick model I worked up, not intended for manufacturing. To do this better, you would need to properly constrain everything, use real life dimensions, and change up a few of the features.
Legend of Zelda Master Sword (Breath of the wild) - MP
https://cad.onshape.com/documents/18fce584d3ab34ccc5ff5df4/w/37152a392e087e5e96a7a7c8/e/ea217e5b0a4b45db677ddb98Learn more about the Gospel of Christ ( Here )
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
