Automatic Feature Folders from which part the features affect
 maximilian_schommer
                    Member Posts: 32 ✭✭
maximilian_schommer
                    Member Posts: 32 ✭✭
            So this is a two part improvement request. First is that feature folders can include features which are not necessarily consecutive. The reason for this is that I would like to be able to put all features which affect a certain part in a single folder, that way it is clear which features are modifying which parts.
Next I'd like an automated way to put all features in folders based on which parts they affect. This would make it really easy to organize part studios, and see what features are doing what.
Max
                3
And features that affect multiple parts?
I could have a feature that modifies Part 1, but later on, a different feature deletes Part 1 or merges it with a different part. In another scenario, something like a pattern could have several references and create many many parts. In these cases, it could be hard to automatically create useful folder structures.
Instead of folders, I wonder if a simple filter that only shows features affecting a certain entity (could be a part, sketch, plane, surface...) could be interesting. It would just work backwards through all feature references and hide things from the feature tree that are not used. In this way, the order of the features is maintained, but you are still able to more quickly see that changing Sketch 10 affects Part 5, for example.
**The more I think about this, being able to quickly query dependencies throughout an entire model tree like this could be really useful for making changes to models (especially if its something someone else made or you haven't worked on it in a while). It could really help avoid problems where editing one dimension in an early sketch has unintended downstream consequences.
I do think being able to see all of the dependencies in the model more explicitly would be interesting.
I'm thinking back to one part studio I have with a couple hundred features, multiple parts, and multiple configurations for those parts. I would imagine any visualization of all those connections would be too busy to be useful without some serious filtering. But maybe all it would need to do is show me "what is affected if I edit feature X". That could really be useful for "debugging".
