See/find mate features associated with a part? (in an assembly)
jesse_silverjesse_silver Member Posts: 2
Hi there, trying to figure out how to identify which mate features are associated with what parts! :(  For example, I want to change how a part is mated within my assembly, and potentially delete some mate features and add new ones. I click on the part in the parts list but none of the mate features light up (which is the UI I would expect). I can't move the part because other things move with it... what am I missing here? I know it must be something... :)
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    To see the parts related to the mates, select the mate in the Assembly List and the parts will highlight. If you expand the mate and hover over the mate connector the individual part will highlight.
    I will add you to the improvement for seeing the mates from selected parts.
    Andy Morris / Head of Product Design / Onshape, Inc.
    +1 on seeing the mates from selected parts
  • michael3424michael3424 Member Posts: 758 ✭✭✭✭
    +1 from me, too.
  • jesse_silverjesse_silver Member Posts: 2
    Thanks for the feedback, andy! Yeah, I know I can do that, but it means I have to click through like 40 mates until I happen upon the one (or several) relating to the part I am interested in... super inefficient. Anyway, +1 on feature request :)
    edited July 2015
    @jesse_silver, You can easily identify by simply clicking on mate connector it will highlight part which it associated. After that you have to click on highlighted part in model space to highlight in model tree.
    @viru : I think you misunderstand @jesse_silver's point
    He knows how to find the part associated with a particular mate.
    He needs to find the mates associated with a particular part.
    At present in Onshape, this is a bit like trying to use a telephone book to find out the name of the person with a particular number.
    While it is possible, it is not very practical.
    edited July 2015
    @ andrew_troup and @jesse_silver , If that is case then there will be one workaround to find the mates associated with a particular part by suppressing the that particular part user can get failed mate associated with that part.
    @viru : great diagnostic tip. Thanks for the reminder!
  • Terry1Terry1 Member Posts: 5 ✭✭✭
    edited August 2015
    +1 for showing mates connected to a part when selected. This makes more sense when an assembly gets busy. A right click "show mates" dialog popup similar to Solidworks would be great.
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    Still not working in 2020?
    @rune_thorsen229
    There is a show mates item in the right click menu  if that helps
    MBartlett21 , sorry where do you find that?  I click on the part and I want to find its mates and I hoped they would light up.
    Thanks in advance for your clarification.
    @rune_thorsen229
    Morgan is saying that if you right click on an instance, one of the menu items will be "show mates"
  • avery_seemanavery_seeman Member Posts: 2 EDU
    for anyone looking for a solution, if you put your mouse over a mate in the instance list, it highlights the associated parts weather or not they are hidden. my method is to show just one part, and scroll through the mate list until that part and the other one I need is highlighted.
