Constraint reference parameters: local0 vs. localFirst?
I noticed that the local entities referenced by a constraint can either be referenced via parameter IDs localFirst/Second or local0/1 (the midpoint constraint seems to uniquely use localEntity1/2).
Is there a difference in function between these?
Likely local# is used for constraints that can have more than 2 references, and localWord is used for constraints that only have two. Sketch constraints are considered internal, and consistency is not guaranteed here.
