How do I dimension an angled line with a radius to theoretical sharp?
scott_kruger
Member Posts: 4 ✭✭
in Drawings
I have an angled line that has a radius at the face of a bore. I am not able to dimension the diameter of the hole created by the angled line in my drawing because of the radius. I have the theoretical sharp point dimensioned in my sketch but I cannot get that dimension to go into my drawing. None of my sketch dimensions will show up in my drawing.
1
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
@scott_kruger @pete_yodisscott_kruger said:I think I figured out how to get the dimension I wanted. I just over rode the dimension that was given in the drawing.
It would be great if you could add a note such as TSC (theoretical sharp corner) and even a tolerance but unfortunately after overriding a dimension you can no longer do neither. Please add me to a request to accomplish this.
Thanks
_Ðave_
4
Just don't ask anyone to inspect that dimension on the shop floor with a set of calipers or micrometer
Thanks
_Ðave_
