Create Mate connector tangent to surface
 gauthier_östervall
                    Member Posts: 99 ✭✭
gauthier_östervall
                    Member Posts: 99 ✭✭
                                  in General
                    I am trying to create mate connector tangent to a surface. Actually, I think I would like to have them from a curve, but they seem to need a surface or part. That's ok.
Ideally, I would like the blue to be normal to the surface, and either red or green tangent to the surface. I cannot apply direction the way I want. How do I do it? Here's the project.
Thanks!
Thanks!
I would recommend sketching a construction line in the direction that you want the mate connector to point. In this example, I made a line tangent to the curve. The line can be used to determine the location and orientation of the mate, and the owner of the mate is the surface. Here is a link to the example. Hope this helps and good luck!
https://cad.onshape.com/documents/4e4b7b8491630936cefac3c8/w/6ba09cc57c0670d19ace7eff/e/922f1028e6920a5953e8593a
Thanks for your reply! I got this far in the original project, I just hoped I could tell Onshape to align the green or red to that construction line. But even trying to align the mate connectors secondary axis to that construction line doesn't work.
Now I see, that I should have a radius as a construction line, that would probably work.
If you select "move" in the dialog, you can also rotate the mate in either X Y or Z after the initial placement. Is this what you are looking for?
https://cad.onshape.com/documents/5d8da63844bedebe5cff72b1/v/a2f8d68037aff39e9d20f7a1/e/11dcab8f665add80b9aced0a
