Advanced: using Release Management (PDM) AND a PLM system side-by-side
andres_dandler
Member Posts: 17 PRO
Hello all,
This might be a little advanced for some, but I hope it triggers a good discussion that I can learn from.
We are are medical device company and we use a PLM system (Propel) company-wide to release documents officially (not just drawings, but ALL company documents, down to purchase orders and employee training records). The PLM system is the official record as far as our Quality Management System (QMS), and it's subject to FDA audit. That's where we generate part numbers, route ECO's, and handle approvals company-wide. The Onshape database, even including Release Management, is not part of the QMS. However, we are using Release Management in Onshape as well. (I have done this in past lives, using for example SolidWorks PDM in conjunction with Agile PLM or Omnify PLM.)
I'm writing the procedure (SOP) for us to do this, but I was wondering... is anyone else out there using both? Any chance we could discuss your SOP?
The trick is how to keep the two databases synchronized so that the revisions match.
My method is as follows:
Are any others using any similar system? Is there any other way to keep the revisions synchronized when the two systems are not actually talking to each other?
Thanks!
-Andres
- Create a Rev in Onshape. Make sure everything is tip-top including drawings and their BOM tables. This can be tedious especially when it's an assembly with subassemblies and lots of parts, but so be it.
- At the same time, I put together an ECO in the PLM system, making sure I'm correctly getting all of my part numbers, revisions, and BOM structures. I upload PDFs of the drawings, as well as STEP files of any custom parts. Note: I do not use the watermarks on drawings. In my revision table, I have an approval box, but it just says "See ECO" because that's the official QMS record.
- Once I'm comfortable that there's perfect agreement between my ECO (in our PLM) and the Release (in Onshape), then I FIRST kick off the Release in Onshape and push it into approval.
- In the Release, I ask my colleagues to review and approve through Onshape's Release Management. IMPORTANT: The trick is that I ask my boss to act as the "gatekeeper": I ask him NOT to approve it in Onshape until it's been approved in PLM. (I will explain the importance in a few lines below.)
- If any of my colleagues (or my boss) reject it in Onshape, then I can go back into Onshape and fix whatever needs to be fixed. The ECO in PLM is not in circulation yet, so it can also be updated if necessary.
- If all of my colleagues approve it in Onshape, then I ask my boss to review it as well. If he approves it, I ask him to just send me an e-mail, but NOT approve it in Release Management yet (see point 4 above, about the "gatekeeper").
- Now I submit the ECO in our PLM system for circulation, review, and approval.
- The best outcome is if the ECO is approved without any changes. If that happens, then I ask my boss to go ahead and approve in Onshape as well. That way, the two systems progress to the new revision in a synchronized way.
- If the ECO in PLM is rejected, that's OK because I can go back into Onshape and make changes, because the Release was not approved yet! That's the beauty of the "gatekeeper" concept, as tedious as it is. So I can go back into Onshape, make changes, then go back through the cycle starting at step 3 above.
Thanks!
-Andres
1
- create drawings
- create ECO
- iteratively review ECO and draft Drawings to make sure everything is good and everything matches.
- Create and release revision in Onshape (not officially reviewed/approved at this step)
- print PDFs, attach to ECO
- approve, sign, and file ECO.
@and@andres_dandler - I thought that Propel had some way to integrate with Onshape directly. Does that not help in this situation?I really think there's a lot of potential to integrate things like this, but some roadblocks I've found are:
@tim_hess427 , your process seems similar to what I've been doing. Do you mind if I ask you to elaborate on a couple of points?
- Could you explain what happens if someone rejects the ECO during your step 6? That's when it gets circulated not only to the engineers, but also to others in the company. Someone might reject it for whatever reason. If you have already released the Onshape drawing (your step 4), then you would have to pull it back to unreleased in order to make changes, right? I'm not sure you can do that in Onshape (at least I know that you CAN'T do that if you're using Onshape's "release management" functions.
- Are you using watermarks of any kind on your drawings? I don't. And by watermark I mean anything that indicates the In my magical dream world, I would have a watermark on my PDF drawings that says "unreleased". However, as soon as the ECO is released in PLM, that watermark would disappear! (But without changing attachments - that's the rub!)
- How do you store CAD files if you’re paper based? CD-ROMs like in the ’90’s? Floppy disks? :-)
And about your bullet points:Thanks for participating in the discussion!
Have others implemented similar workflows bridging PDM and PLM systems?
-Andres
It's helpful to me to read your description of the system you're using. It does sound very similar, except or system relies on killing more trees.
To answer your questions:
- In our process, we sometimes use the terms ECN and ECO interchangeably. So, really, I should have used "ECN". Before anything is "approved" in Onshape or on the paper ECN, everything is reviewed by all appropriate people in the draft state. Once everybody is happy with everything the paper ECN is signed and the onshape drawings are released "simultaneously". Its not fool proof, but it works OK with a small team where there's only a few people that have to review the documents. Also, we fill out the Rev tables on the drawing manually, so if the revision listed in the Onshape properties was different from the revision listed on the PDF drawing, the PDF drawing would be "correct" because it's the controlling document in the paper system. It would just be confusing for people working in CAD.
- We use watermarks in Onshape only. And that's just in case somebody is looking at a drawing in Onshape, we want them to know if its unreleased or not. The ECN paperwork is all done in microsoft word, printed, signed, and then scanned as pdf.
- For drawings and documents, we keep paper files and PDFs on a server. 3D models are exported to step files and saved on the server.
- Right now, we have 2 full CAD licenses. I'd like to have one "light" license for approvals.
- Your correct on the audit trail comment - our controlling system is the "paper" system and like yours, the Onshape documents aren't part of the "controlled" system. My comments about audit trails and validation were looking ahead to a day when Onshape could be a part of that system and streamline some things.
Thanks for starting the discussion!If you're trying to keep two systems in sync, would it be easier to NOT use release management in Onshape? This way you can modify things in your onshape drawings until they are they way you like them, update the revision table manually, update the revision level in Properties, and export your PDF. Once everything is approved in your PLM, you could just go back to Onshape change the state from pending to Released and create a version.
I've been thinking about this approach because I've run into a couple issues where the drawings look good in the draft state, but then I run into some issue in the release process that forces me to change a linked document or something and creates issues. Or, in some cases, I'm can't fully update an assembly drawing draft until the linked sub-assembly or part is released and updated, which could create other surprises. In one recent situation, someone accidently released an incorrect configuration for a sub-assembly. The configuration only controlled part locations, so the BOM was correct, but the drawing views weren't and I've got no way to change the part number and Revision to the correct configuration. If we weren't using release management, I'd be able to correct this manually.
The downside to this is less visibility into the release history of a part while you're in onshape. Being able to search for "released" parts should still work, but you wouldn't have the helpful triangle icons throughout the UI. The upside is that I think your release process could be a little more flexible.
https://www.youtube.com/watch?v=Jw3Kp8Vy3Qo
CAD Engineering Manager
