Modern CAM. Finally?
Cache_River_Mill
Member Posts: 225 PRO
in General
We now have modern CAD software, Onshape! This is awesome.
I have searched all over for modern innovative 5 axis CAM software. It doesn't exist...
Please let us know if you have found it. Everything we find does not use the 2018 computers calculation skills like it should.
There are a few ones integrated with Onshape
@cache_river_millworks
I use Onshape for design, then export models as either Solidworks or Parasolid formats to a Dropbox location. Then I use Fusion360 (cloud based) to import the exported file (or files). Excellent CAM results from there. Fusion360 uses HSMWorks CAM functionality.
I personally do not have 5 axis capability, but I believe Fusion360 can output 5 Axis Code.
Of course you lose parametric capability by this method but I can work around this if I need changes by going back to Onshape, implement changes and repeat the export/import routine. Sometimes I simply implement small changes in Fusion360 itself.
If only Onshape had fully integrated CAM capability like Fusion360, I would switch entirely to Onshape.
VisualCAMc is an Integrated Cloud App. And it is fully associative. change the part, toolpaths update. And your CAM is version controlled.
VisualCAMc is a fully cloud based production level CAM application for Onshape
This powerful application includes production ready tools and functionality for programming Milling CNC centers. VisualCAMc includes functionality for 2 ½ Axis, 3 Axis and 3+2 Axis milling functionality that is ideal for mold, die and tooling, wood working, production rapid-prototyping, education and general machining markets
Features of this product include:
Thanks for the heads up.
I was aware of VisualCAM. Unfortunately, I don't think is can handle CNC Lathes. I use both mills and lathes.
@joe_dunne - are you aware of any Onshape customers that use SprutCAM? I use it for 3-axis milling and turning but mostly as a hobbyist.
I would not recommend it.
Fusion 360 cam package is really nice and getting better and better. They are merging all of the Declam products into fusion (Power mill, Feature CAM, part maker etc).
I just don’t see Onshape having a native CAM solution anytime in the next 5 years....I could be wrong.
I think Onshape is more focused towards the engineering firm market and fusion is more focused towards the manufacturer.
I will say there are tremendous benefits of integrated CAD / CAM for a manufacturer. We are using fusion as our CAM solution more and more frequently.
We even use fusion for simple 5 axis positioning now.
If anyone is making this, please contact me if you need any help. I would love to help and be apart of this revolutionary CAM software.
But I have design's , Ive started creating featurescripts that'll complement the app and I am fully commited to this. Email me: chris@dzigninnovations.com.au if you'd like to discuss. Any help I can get I will take.
