Extruding to plane
in Drawings
Hello,
I am trying to remove the highlighted part of my drawing down to the plane, which is set at a 20 degree angle. Is there a way to remove extrude to a plane, or any other way you see to deal with this issue.
Thanks
Thanks
Change "Up to next" to "Up to face", and select the plane. You will probably also want to change "Intersect" to "Remove"
You will probably also want to deselect the top and back face that you have selected. You will only want to select the side face that needs to be extruded.
