Tool Bar Inactive
kent_agnekent_agne Member Posts: 3
Just starting to "learn" - When I press the Sketch Button, the tools turn opaque and inactive - HELP
I've dabbled before and don't believe I've seen this problem.  I'm using Edu version on Windows 10 in Chrome browser.
  • timandrewstimandrews Member, Moderator, Onshape Employees Posts: 18 image
    edited April 2020
    @kent_agne, after pressing the Sketch button, you must select a sketch plane in order to use the sketch tools in the toolbar. Hope this helps you get started!
