Does anyone know if there are plans to allow Onshape to import Creo .mtl material files?
peter_z
Member Posts: 4 PRO
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
At the moment I don't believe OS supports importing any other format than a basic CSV file with only 3 fields - category, name, and density. See the workflow for importing a new material library. MTL files are just ASCII, so you should be able to extract the info to paste into a spreadsheet/CSV. If you have a lot of materials, you might even be able to automate the process via a macro or similar process.5
