Boolean "Keep Tool"
allen_stewart
Member Posts: 32 ✭
Hello Everyone,
Im new to onshape and I am trying to learn all the features. Can someone explain to me what the "Keep Tool" with regards to the Boolean subtract is? Is there also a in-depth explanation of all the tools and features?
thank you
nav
Member Posts: 258 ✭✭✭✭
Hi @allen_stewart the keep tool in Boolean subtract if active will keep as a part the part you subtract from the model, if not active if you have two parts it will keep only one part in your model.
There are a lot of learning sources for OS, the one more comprehensive is the online help https://cad.onshape.com/help/
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5 -
raino_paananen
Member Posts: 17 ✭✭
And BTW. those "I feel like an idiot" moments are not new to any of us CAD users
Raino5
If you are using the first part solely for this purpose, you would not normally want it to hang around in the model afterwards, but if the "tool" is a functional part (as in the pins in the cantilever clamp in the wonderful Onshape tutorial) then you would choose "Keep tool"
I feel like an idiot but I still don't get it. Explain it like you would to a 12 year old.
Boolean subtract makes a hollow in Part B wherever Part A is inside it.
Part A is called the Tool (and part B the target ?, from memory)
If that's all you wanted to use Part A for, then don't keep the tool.
This is a situation where you DO want to "Keep Tool"
If you locate two solid bodies together in a way that they are interfering each other. You can Subtract the overlapping volume from either one of the bodies to make the two parts fit etc. In this boolean operation one of the bodies is used as a tool to cut from the other part. If you don't tic the keep tools box, the body that you use as a tool will disappear after the operation. If you tic the keep tools box, The same operation will happen but both bodies will be kept in the part studio. Hopefully the pics will help.
Raino
Raino
Almost the earliest recorded capture of "written" info (I seem to recall) is Sumerian clay tablets, popular 5 millennia ago, where a wedge-profile tool was pressed into the soft clay, to form complex characters with simple wedge shaped elements, called cuneiform (sp?).
I think the tool was called a "stylus" (not by the Sumerians, but by those who came later)
The "pages" were highly durable once they were fired in a kiln. I think the style of character had originally started as a form of book-keeping, which Sumerians were obsessed with. (A bit like our four verticals with a diagonal slash to keep a tally)
