Catch on linear pattern
Kai_himselfKai_himself Member Posts: 45 ✭✭
Hello,
im trying to catch a point with my linear pattern function.
But the point is not catched, even not the horizontal axis... how do i do it ?
Im trying shift + s to get the catch mode, but it wont work.
Id like to get the orange rectangle over the orange point.
Best regards
Kai
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    You have to delete the distance dimension in the linear pattern first. Right now it is reading as 112.402. If you select that and delete it, then you should be able to reference the point.
    Twitter: @bradleysauln
  • Kai_himselfKai_himself Member Posts: 45 ✭✭
    Thank you very much !
