Mobile App on IOS Mirror Troubleshooting
Japes777
Member Posts: 3 EDU
When I select Mirror it comes up on the left sidebar as Sketch4 (all the tutorial videos show it as mirror, not sure if this is an issue). The trouble is: I can select a sketch plane and an offset plane to mirror from but after that I cannot select the whole part I want to mirror. Can someone advise me? I am using iPad Pro and am trying to complete the hinge tutorial on YouTube from Onshape Pro channel.
Is the mirror function meant to show as mirror or sketch in the left sidebar?
How do I select the whole part?
steve_shubin
Member Posts: 1,118 ✭✭✭✭
@jp_hampshire348To me it sounds like your selecting the wrong Mirror tool
Sounds like you’re selecting the Sketch Mirror tool instead of the Features Mirror tool
5
EDIT: I just tried it and it worked.
Thanks so much.
