Syntax for Example 3 in Feature List API
I am trying to pass the code below from example 3 thru the API Explorer.
I get this error:
I get this error:
error: " JSON syntax error"
They are asking for the following:
"script": "String",
"queries": "Object[]",
"queries.0.key": "String",
"queries.0.value": "String[]",
"serializationVersion": "String",
"sourceMicroversion": "String",
"rejectMicroversionSkew": "Boolean"
I am not sure what to put in for the other values. Any ideas?
If I copy and paste snippet directly from Example 3 webpage into API Explorer it gives error. If I copy into a formatter such as http://jsonviewer.stack.hu/ and format. Then copy paste into API Explorer. It works.
