True barrel cam slot? (rifle bolt cocking cam)
 kevin_battenbough
                    Member Posts: 4 ✭
kevin_battenbough
                    Member Posts: 4 ✭
                    https://cad.onshape.com/documents/905497f0f18a766f33c2e141/w/c45ed847e51b967cf7a5e40f/e/f28e547a4aad4d946b03fe54
Hi Guys
Im trying to place a cam on the back of a rifle bolt which is essentially the same as a barrel cam....I have followed a couple of vids on youtube and while it would work on thin walled tube.....I'm not getting a true cam, both extremities of the cam look to point to the bolt central axis which is not right....I want to replicate a 4.5 endmill first cutting the slot and then milling out the cam.
I have tweaked every feature edit ect and can't get it to work.
Much appriciated.
Kev
                Hi Guys
Much appriciated.
Kev
Here is an attempt I made. I changes a few things for where the helix started from. Let us know how you make out!
https://cad.onshape.com/documents/8221410c2e8066508a60c3df/w/cff94f01bbf9563290375f2a/e/108aaaf6146d5c48d3f6a246
