Curve Pattern Question
ethan_doak1ethan_doak1 Member Posts: 11 PRO
So, I've used the curve pattern tool to great effect when adding teeth to a timing belt for my assemblies, but when I add a bend to the belt (using a tensioner in this case) the Curve Pattern ends up throwing teeth all over the part studio (instead of following the curve I laid out for it)
What do you think I should do?
    edited June 2020
    Hi, could you provide a link with some minimal reproducible example?
  • ethan_doak1ethan_doak1 Member Posts: 11 PRO
    Alright well, I was trying to curve pattern using a part from the assembly that my part studio was created in context of. This has always worked for me before but didn't this time. I redrew the part that I was using the curve pattern on so that it was a part of my part studio and it worked great. Not sure what caused my issue but it seems to be fine with this work-around.
