Curve Pattern Question
ethan_doak1
Member Posts: 11 PRO
So, I've used the curve pattern tool to great effect when adding teeth to a timing belt for my assemblies, but when I add a bend to the belt (using a tensioner in this case) the Curve Pattern ends up throwing teeth all over the part studio (instead of following the curve I laid out for it)
What do you think I should do?
