create app in dev-portal.onshape.com
freeshapefreeshape Member Posts: 6
when i create a application in dev-portal.onshape.com successfully
but i can not find my created application in my account in cad.onshape.com
can any friend help me?
  • Ethan_KEthan_K Member, Onshape Employees Posts: 57 image
    You should be able to find and subscribe to the app you created in the appstore here: https://appstore.onshape.com/. What you are looking at is the apps that your account is currently subscribed to. Hope that makes sense!
  • freeshapefreeshape Member Posts: 6
    thanks for your answer, the problem is i can not find the application in appstore which i created
    update!  i find the application the  created by myself and subscribe it, it`s now in myapps category (show below)
    however it still not apper in my account`s applications
  • alexander_koppelalexander_koppel Member Posts: 5
    Was this thread ever answered? I am having the same issue. I have created an app plus extension and can subscribe, but after subscribing the app does not appear in the "add applications" tab. I added a different application to show that the tab works as intended, but my app is missing from it.
  • caden_armstrong2caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    edited June 2022
    @alexander_koppel Do you have the context of your extension set correctly?
    Sorry I never responded, but while I was never able to get the application to appear there, I was able to get the extensions to appear elsewhere in the "Element Right Panel".
