String Parameter won't reference a Text Config Variable
sam_parsonssam_parsons Member Posts: 43 PRO
Hey Guys,
I'm trying to use a custom feature to assign materials to parts. But I'm getting tripped up by the string parameter. I can't seem to configure the parameter using a text config variable? Presumably because "#" becomes part of a string and loses it's ability to signify another variable?
Here is the annotation in FS:
annotation { "Name" : "Core Material", "Default" : "Default" }
definition.coreMat is string;
Any thoughts would be greatly appreciated!
Sam
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    edited June 2020
    Instead of defining the annotation as a string, define it as a field that accepts anything (including variables). As you said, forcing the input to be a string will just use whatever text you enter as is, including the #.
    So instead of
    use
    isAnything(definition.coreMat)
    Keep in mind that this will allow just about anything to be entered - variables, functions, numbers, booleans, and of course text strings. To insure whatever is entered is treated as a string later in the FS, you may need to typecast via toString().
    Alternatively, you can use a little coding to remap the #variable to its value.
    See an example function I have for doing that below:
     * This function maps variables denoted by `#variable` to the appropriate variable in the context.
    export function remapVariables(context is Context, text is string) returns string
        // An optimisation if there is no variable references
        if (replace(text, "#", "") == text)
            return text;
        var variables is map = getAllVariables(context);
        variables[" "] = ""; // Replace "# " with ""
        var out is string = "";
        const chars is array = splitIntoCharacters(text);
        const charsSize is number = @size(chars);
        for (var i = 0; i < charsSize; i += 1)
            const char is string = chars[i];
            if (char == "#")
                if (i < charsSize - 1 && chars[i + 1] == "#")
                    out ~= "#";
                    i += 1;
                    continue;
                const varName = getVarName(chars, i + 1);
                if (varName != undefined && variables[varName] != undefined)
                    out ~= toString(variables[varName]);
                    i += length(varName);
                else
                    out ~= char;
            else
                out ~= char;
        return out;
    function getVarName(chars is array, i is number)
        var out = "";
        for ( ; i < @size(chars) && nonSpecial[chars[i]] == true; i += 1)
            out ~= chars[i];
        if (out == "" && i < @size(chars) && chars[i] == " ")
            return " ";
        return out == "" ? undefined : out;
    // This uses a function to generate a constant.
    const nonSpecial is map = function()
            const chars = splitIntoCharacters("1234567890_qwertyuiopasdfghjklzxcvbnmQWERTYUIOPASDFGHJKLZXCVBNM"); // All alphabetic characters
            var out = {};
            for (var char in chars)
                out[char] = true;
            return out;
  • sam_parsonssam_parsons Member Posts: 43 PRO
    Perfect! I'll try this for now.
    But I can see how this would be useful long term, just not sure I know enough about feature script yet to implement it. Do you just include this in the custom feature code?
    @sam_parsons
    If you put the code above in your FeatureStudio, you can then use it in your code just after the end of the precondition:
            definition.codeMat is string;
            // The rest of the precondition
        } // End of precondition
        { // Start of feature body
            definition.coreMat = remapVariables(context, definition.coreMat);
            // Continue the rest of the code
    ok thanks, I may try this at some point. For now, I've got @mahir 's method working... however... I get the same problem when I insert that part into an assembly, I get the same issue in the change configuration in UI. Any ideas?
    @MBartlett21 , would your method solve this ^ ?
    @sam_parsons
    Unfortunately not :(
